DTC P1166 Primary O2 heater circuit-ECU PIN DIAGRAM NEEDED?
jongearparts
Have not had a problem in the last 4 months and I get a cell last night for a primary o2 heater circuit, checked at the connector by the exhaust, everything looks good mechanically. I want to check the resistance and a voltage drop from the ecu to the connector @ o2. I need the ecu pin diagram and which of the four wires at the o2 sensor is the heater circuit feed. Im assuming its a 5voltage signal to heat the o2? thanks in advance.
jongearparts
