kpro for 03 accord
cstyleaccord
kpro for 03 accord
Post by cstyleaccord »
i have a few question to ask, if anyone know this better. in order for me to use kpro in the accord k24a4 i would need a 02-04 rsx ecu? and not using the accord ecu correct? and i would still need the harness? can i use a kpro for the civic si k20a3? thanks
Dominic..
Post by Dominic.. »
propably accord 2.4 has rbb ecu and 4 plugs... so you can try connect rsx ecu, but for sure you lost most function in car, like climatronic,etc,etc.
www.Ecu-Performance.com.pl
Euro CTR Boost - 1/4 12.066s ET
cstyleaccord
rbb ecu? can you explain more on that? and it only has 3 plug just like any other k20a ecu manual tranny. yeah i heard i will lose some function such as the speedo etc.
but i'm really curious as to whether i need an rsx ecu kpro to make it work in the accord as Hondata said that kpro will work. I'm just wondering if they mean by using a rsx ecu or do i need my own ecu.
"This uses a 2002-2004 RSX ECU and an adapter harness. You will also need the Primary oxygen sensor from the 2002-2004 RSX. We will be offering an 05 K-Pro bundle that the user provides an ECU and we then modify the Ecu and add the K-Pro and include an adapter harness. This solution allows the speedo to work properly as well as all sensors. This kit will also work on the manual transmission 03-04 Accord, but will not run the instrument cluster."
Its this part above that make me really confuse.
