No spark hondata H23A
Thatgreycrv
Post by Thatgreycrv »
Hey I have a h23a swapped crv with a hondata cpr I’ve installed all of the wires correctly on it but I still seem to not have any spark I tried spark plugs grounded but there’s still no spark my lights work perfectly I have constant power ignition on 1 second and the sync works at 2 seconds I have brand new coils and spark plugs and there’s no spark I did a base map and enabled the cpr.
if anyone can please give me any info on this problem I will appreciate it thank you.
Re: No spark hondata H23A
Are the sync and ign solid or flashing?
Thatgreycrv
They are flashing when I turn ignition
Was there spark before installing the CPR?
Thatgreycrv
No it didn’t have any spark at first
It sounds like there may be some other issues then as you should have it running before trying to install the CPR.
Thatgreycrv
Yea the thing is that I bought the engine with the car and I did the swap but I’ve never turned the car on before so it’s the first time
You need to get it running then without the CPR first.
