On Board Datalogging not working...
Shadow!
Post by Shadow! »
after use "Delete all"
in window "Download from ECU"
Memory
Used - 2047k
Free - 0k
Total - 2048k
but no any recordings
Make a short datalog first, then use the delete all function.
Shadow!
Post by Shadow! »
Hondata wrote:Make a short datalog first, then use the delete all function.
I can't make any recordings, onboard datalogging not start, because memory full I think.
Shadow!
Post by Shadow! »
Spunkster wrote:try it before saying it won't work
I did try to start any recording to ECU memory many times, really.
Some time ago On-Board Datalogging worked normally.
It is a garbage collection problem. I've altered SManager so that the 'Delete All' button should reset the datalogging memory, even if there are no recordings. This version (1.1.3) will be released later today as a beta.
Shadow!
Post by Shadow! »
Hondata wrote:It is a garbage collection problem. I've altered SManager so that the 'Delete All' button should reset the datalogging memory, even if there are no recordings. This version (1.1.3) will be released later today as a beta.
Wonderful ! I solved that problem with 1.1.3 version.
