why base maps are so different that true maps i found in stock roms ?
ex : pic fuel in stock P73 ECU is about 725 and in S300 is 840...
ex2 : pic fuel in stock P30 JDM is about 680 and in S300 is more than 900 ?
base map
base map
Nicolas DARNIS
HRED Motorsport
HRED Motorsport
Nagata-San74
I already saw this post but it is not what i see...Nagata-San74 wrote:http://hondata.net/forum/viewtopic.php?t=4356
Basemaps are just as close as possible to stocks
Nicolas DARNIS
HRED Motorsport
HRED Motorsport
Nagata-San74
jdmspecdc5
i also see this difference in stock maps. the stock maps from uberdata or crome are different from the hondata stock maps. one observation is the timing in the hondata maps seems to be advanced at least 2* all around. fuel is a bit different too as is the pressure/vacuum values for the columns. maybe it's just the way the two programs pull a stock bin from the ecu.
No, I compare similar maps US with US and JDM with JDM.
For timing, it's ok.
For Fuel, i think it is an anti copy of fuel maps, (may be a multiplier is inside the S300 code to correct the fuel maps), so it is impossible to copy all fuel values from S300 into a stock rom after tuning with S300.
I said may be...
I said may be...
Nicolas DARNIS
HRED Motorsport
HRED Motorsport
