Kpro v4 connection problem on-line off-line
EGK2082
Post by EGK2082 »
kpro v4 I have a problem connecting and disconnecting (on-line/off-line) I changed the cable thinking that was it, it gives me an error
EGK2082
Re: Kpro v4 connection problem on-line off-line
Post by EGK2082 »
It connects on-line and after a short time it disconnects off-line by itself and like this every moment, I don't have time to do anything, I changed the cable thinking that was it
MondeCruel
Post by MondeCruel »
Make sur you have internet connection at the time you launch kmanager
EGK2082
Post by EGK2082 »
being connected to the internet the same thing happens, it connects and disconnects all the time
What is the serial number that is on the K-Pro board inside the ECU?
EGK2082
Post by EGK2082 »
Are you using resistor or non-resistor type sparkplugs.
EGK2082
Post by EGK2082 »
Using resistor
When did this problem start, and what has been changed since the last time it was working?
EGK2082
Post by EGK2082 »
I think my notebook was not working well, I reinstalled everything again and so far it works correctly.
good to hear
