I am using K-Pro4 with a PND ECU, Rywire K Series Budget Tucked Engine Harness and EF K-Conversion wiring harness.
Also have:
- MTX-L a/f wide band ho2 sensor and gauge (Bosch LSU4.9)
Skunk alpha 2 header 4-2-1 @ 2.5"
2.5" Thunderbolt Universal Catalytic Converter with 2.5" Exhaust
70 mm throttle body with an Acuity K20 RSX TPS Hall Effect
K20 oil pump
Stock 25 degree timing
Stock fuel injectors
Universal A/C & P/S Eliminator Kit
The second time I started it, the header did not glow orange, but then again, I didn't let idle as long. My a/f was reading 15 +/-1.
Wondering if a different base calibration is needed and if I can get by with just an E-tune?
Thank you,
