Need help with a 07 si k24a2 base map tune to move the car around
Olmedaeric
Post by Olmedaeric »
I need help learning how to tune the car for a base map tune at least to get it home from the shop everything is original on the k24a2 except the intake from the k20z3 would appreciate the help
CalibratEd
Re: Need help with a 07 si k24a2 base map tune to move the car around
Post by CalibratEd »
Welcome to the forum,
The forum might have an 8th gen k24 calibration. You can use that as a reference. No two cars are the same so it will need modifications. How far is the shop from your home?
-Ed
Instagram: calibrated.tuning
Olmedaeric
I wanna say with traffic close to 45 with out 30
CalibratEd
Have you tried loading any files? I see you posted that you want to learn. I can review the file and give you pointers. Post the file if you have tried running one and a datalog.
- Ed
CalibratEd
Some user have ran this file temporarily. It's from another tuner on the forum EFICU. You can use it as a starter. Keep in mind it will need adjustments.
viewtopic.php?t=25121&start=45
-Ed
