Hybrid Racing CAI Stock everything else Hondata Base MAP
Hello all, I am new to this and just starting today looking up information. I have tried searching and looking up what to run and how to set up my car when I add the Hondata and HR CAI to my car. is there a tune that I should be looking into? I will continue to look through this forum. I felt if I asked early I can be steered into the right path
Re: Hybrid Racing CAI Stock everything else Hondata Base MAP
With the HR intake, the main thing you need is to find a calibration that runs the car speed density using the MAP sensor. A MAF sensor tune will cause a lot of issues and run terribly. There are a couple calibrations I believe that run the MAP sensor, you can start with one of those but they will need adjustments to be optimal for your car. Don't upload one and go out beating on the car, make a 20-30 minute datalog or so and see how things look before you have too much fun with it.
If you want some help with it let me know. Do you have any future plans for the car?
Hello, I also have an 07 civic SI all stock except for the hybrid CAI please advise on base map and all the help you can give me would be greatly appreciated. Thank you.
- CalibratEd
- Contact:
SICcivic wrote: Sun Aug 13, 2023 10:30 am Hello, I also have an 07 civic SI all stock except for the hybrid CAI please advise on base map and all the help you can give me would be greatly appreciated. Thank you.
Welcome to the forum,
I suggest to start with a base calibration with modifications closes to yours and then dial it in. Any Hondata base map you use will need some adjustments. I also suggest you start your own thread.
-Ed
Instagram: calibrated.tuning
