Acuity intake basemap
CalibratEd
Re: Acuity intake basemap
Post by CalibratEd »
Rev hang was not turned off on the calibration. I went ahead and turned it off for you and made a few fuel adjustments.
-Ed
Instagram: calibrated.tuning
Gunish
Post by Gunish »
Everything feels so much better. I posted city and highway datalogs after the last map. If you could just confirm if it's still running lean or not.
CalibratEd
Still running lean at part throttle. In WOT it is fine. I made bigger adjustments to the fuel in part throttle.
Load the file and create a new datalog.
-Ed
Gunish
Post by Gunish »
I'm not sure if it's normal, but when I drop it to neutral, the rpms jump up slightly and then drop down around 900-1200.
CalibratEd
It could be the fueling. I am dialing in the fuel at part throttle.
Load the new file and create a new log.
-Ed
Gunish
Post by Gunish »
Feels better but I feel like at around 3-5k rpms there's a drop in power or something
CalibratEd
This should be good enough to drive around until you get a proper tune. I reduced timing where i saw knock. You might have felt a lack in power if you hit a certain cell in the vtc tables they are not properly optimized. The car will run a lot better once you get a proper tune as all tables will be properly tuned. I made broad adjustments here to make sure the car is running safe.
-Ed
Gunish
Post by Gunish »
Alright, do you need me to post another data log, or should that do it?
CalibratEd
That’s it. Reach it if you every need a full Etune.
-Ed
Gunish
Post by Gunish »
What difference would the fuel etune make?
Gunish
Post by Gunish »
Sorry, read that wrong. I'll send you a pm
Gunish
Post by Gunish »
I made a lot of changes to the map myself. I'm unsure If I made it worse in any way, so if you could check it. I posted a datalog with it as well
