Acuity intake basemap
Hey, can anyone help me with a base map tune just for an acuity CAI and a catback exhaust. I’m waiting to get all of my bolt ons before I put my car on the dyno, so i’m just looking for a map that I could use to daily drive my car until then.
- CalibratEd
- Contact:
Re: Acuity intake basemap
Use a map with the closes mods to yours and switch it into speed density.
I can review the logs.
-Ed
-Ed
Instagram: calibrated.tuning
Thanks for the reply. I’ll post a log in an hour but i’m running the hondata reflash right now with the crackle/ pop tweaks in the ignition graphs. I’m not sure how to change the ratios for fuel and everything so i’ll post the map and the log.
- CalibratEd
- Contact:
Remove all the crackle modifications until it’s dialed in.
-Ed
-Ed
Sorry for the delay. I've attached the map that I'm running and 2 data logs.
- CalibratEd
- Contact:
Remove the crackle modification and redatalog the car.
-Ed
-Ed
So, I'm using the same map now without the pop/crackles, and my EMS light came on for a while, and it went away on its own. I've attached the datalog before it came on and the map.
- CalibratEd
- Contact:
Down low the car needs a bit of fuel added. Up top the car is running very lean. It is hitting 14AFR at WOT and you can damage something driving the car that hard. When you change the stock intake it is best to switch to a speed density tune. What other bolt ons do you have left to install?
-Ed
-Ed
Yea, I could feel it running different. I’m going to be installing a full race in a couple of weeks but for now just the intake.
Here's the map
The datalog
- CalibratEd
- Contact:
Gunish,
I made a few minor fuel adjustments. Load the new file and create a datalog.
-Ed
-Ed
I've attached 2 datalogs. 1 is highway drive and 1 of them is city
- CalibratEd
- Contact:
Gunish,
Cleaned up a bit more of the fuel. It is running lean.
Load the new file and create another datalog.
-Ed
-Ed
The throttle feels a little unusual, I'm not sure why. It feels like there's more rev hang than normal and while rolling the rpms just drop for a quick second sometimes.
