2007 HONDA CIVIC SI HYBRID RACING CAI
J_Lovell2007
Re: 2007 HONDA CIVIC SI HYBRID RACING CAI
Post by J_Lovell2007 »
datalog0003.fpdl
datalog0002.fpdl
datalog0001.fpdl
datalog0000.fpdl
J_Lovell2007
Hey Ed, are these data logs better?
CalibratEd
Post by CalibratEd »
Yes, the logs were good. The calibration needs fuel adjustments. It is running lean. Timing is ok as there is no knock present.
-Ed
Instagram: calibrated.tuning
J_Lovell2007
Thanks for looking into that Ed! One last question should I stay away from high RPM's just drive it normal until I get fuel adjusted?
CalibratEd
J_Lovell2007 wrote: Sun May 21, 2023 12:11 pm Thanks for looking into that Ed! One last question should I stay away from high RPM's just drive it normal until I get fuel adjusted?
Yes, don’t drive the car too hard until you have the fuel dialed in. It’s better to play it safe. Once you make the corrections post the logs and I can let you know if you’re on the right track.
-Ed
J_Lovell2007
Thanks Ed! I'll keep you updated thanks for the advice.
CalibratEd
J_Lovell2007 wrote: Sun May 21, 2023 12:20 pm Thanks Ed! I'll keep you updated thanks for the advice.
No problem.
-Ed
J_Lovell2007
Hey Ed got a tune today, check it out see what you think? I can send more data over if you need thanks!
-Justin
CalibratEd
J_Lovell2007 wrote: Tue May 23, 2023 2:13 pm Hey Ed got a tune today, check it out see what you think? I can send more data over if you need thanks!
-Justin
Post the calibration file from your tuner so i can review the logs.
- Ed
J_Lovell2007
nabil tune.fpcal
CalibratEd
Fuel doesn't look bad and there is no knock. I can't dig deeper because your tuner locked the file. I am not a fan of locked tunes. I never lock customer tunes.
-Ed
