2007 HONDA CIVIC SI HYBRID RACING CAI
J_Lovell2007
So I installed my Hybrid racing CAI and now at start up it stutters and sounds like I have it camed lol. Did notice also when i'm around 4500-5000 RPM and I accel hard it seems like im losing power and bogs down. Did have a code P0701, I cleared it hasn't came back on? I did use my flashpro and uploaded the VEM V2 (I think that's the one). I plan on getting headers and exhaust but not for another year, it's been a slow building process. Didn't know if anyone could help me maybe adjust fuel trim? Thanks in advance
- CalibratEd
- Contact:
Re: 2007 HONDA CIVIC SI HYBRID RACING CAI
Welcome to the forum J,
The Hondata base maps are a good start and still need some work.
Post the calibration file you are running and a datalog. Try not to drive the car to hard.
I can take a look at the logs to make sure you’re running safe.
-Ed
-Ed
Instagram: calibrated.tuning
J_Lovell2007
Thanks for replying, I will send some data logs over tomorrow so you can take a look at them!
- CalibratEd
- Contact:
J_Lovell2007
- CalibratEd
- Contact:
Post the calibration file as well.
-Ed
-Ed
J_Lovell2007
FG2/FA5, AEM V2 CAI
- CalibratEd
- Contact:
J_Lovell2007
J_Lovell2007
Is this it? I'm kinda new to Hondata, still trying to figure it out.
- CalibratEd
- Contact:
I looked over the log and I suggest you switch the calibration file to Speed density and then redo the log.
-Ed
-Ed
J_Lovell2007
Should I have "AFM enabled" AND "use speed/destiny (MAP) fuel tables clicked?
- CalibratEd
- Contact:
Uncheck AFM and check use map tables.
-Ed
-Ed
J_Lovell2007
Ok I have the settings saved now, once im off work I will get more data logged. Do you want cold start data? Also do you want high revs or normal driving? Thanks Ed
- CalibratEd
- Contact:
Idle log after it has reached operating temperature as well as a normal driving log. Do not wide open throttle the car.
-Ed
-Ed
