Hi, I recently installed the latest version of KManager on my laptop to make a single change to my map which was to raise the vtec engagement.
When plugging in it gives me a warning saying that the existing calibration was done on an older version. But I downloaded the settings from the ecu anyway. Changed vtec then uploaded to the car.
Now between 2 and 3.5k it's spluttering really bad and I have to feather the throttle until its past this point.
Any ideas what might have happened?
This is my new daily so need to get it running properly
Running issues after changing to latest software
Re: Running issues after changing to latest software
^ I was just about to make this same post.
k20a2 was running fine since the last time I updated my ECU like a year ago; Wanted to play around with some settings and needed to update to do so.
After updating to the current beta version, I don't know why I did beta :( Now my car wont rev past 2500~3000 rpm. Trying rev and the car turns off after a few revs.
I uploaded the same settings that was working before, I tried a stock calibration but neither are working. I feel like maybe it's something with this new beta? This is my only car so I really need help on this.
I have found the problem with mine. When switching to the new software it completely scrambled my timing map.
For now I've uploaded a base map and manually keyed in the fuel settings from the old map. Until I can get it on the dyno for a remap
