Map sensor options greyed out
Ichiro718
Post by Ichiro718 »
Hello everyone, so i downloaded s300 last night and I'm trying to input my data for the map sensor, but it's giving me issues. I have a Burton racing 3 bar map sensor(are they any good?) And I input the scalar data and the offset data with no problem. Issue is that i can't change the "mbar@5v" value because it's greyed out. The value isn't matching up to the info I'm supposed to input. Can I get some assistance? I purchased the hondata but i didn't receive it yet.
Ichiro718
Re: Map sensor options greyed out
Post by Ichiro718 »
I uploaded a picture of the screen. The value I'm supposed to have at mbar@5v is 3180.
The greyed out parts are calculated fields. You should change the scalar and offset. In any case 3180 is only 1.5%.
Ichiro718
Post by Ichiro718 »
Hondata wrote: Sun Oct 23, 2022 11:07 am The greyed out parts are calculated fields. You should change the scalar and offset. In any case 3180 is only 1.5%.
So there isn't a way of changing that even once I'm connected to the ecu? It's my first time and I'm trying to get everything perfect.
They are calculated from the scalar and offset. eg 5v x 677 - 155 = 3230
I think you entered 677 rather than 667 for the scalar.
Ichiro718
Post by Ichiro718 »
You know, that's a high probability😆 will report back. Thanks
Ichiro718
Post by Ichiro718 »
I'm so silly😆i did have 677 lolol
