Can anyone help me setup a base map for my kswap Lotus?
saxon_schmauderer
Re: Can anyone help me setup a base map for my kswap Lotus?
Post by saxon_schmauderer »
Must have a boost leak somewhere. I know this engine is fully built so i took off boost protection to do the WOT pull and the car seemed fine other than needing some fuel adjustment. See attached for the WOT 3rd gear after 5 seconds of 3k rpm. It looks like it did get some knocking at the higher rpms.
9-10_3rd gearWOT.kdl
CalibratEd
Post by CalibratEd »
Create another WOT pull. I adjusted fuel. The datalog shows the car's max boost was 28.5 pounds. That's far from the 14psi wastegate spring you mentioned. That's why it kept hitting boost cut. I have also gone ahead and removed the boost cut.
-Ed
Instagram: calibrated.tuning
saxon_schmauderer
See Attached:
I didnt see any knocking.
3rd gear 9-12.kdl
-Saxon
CalibratEd
Create a normal driving log with a WOT pull. I am smoothing out the fuel.
-Ed
saxon_schmauderer
I was pushing so much boost because my wastegate shit the bed. Swapped out for a new one and we are back in business. I think I made 13lbs. Did a couple WOT pulls down the road. Run was decent. I think I got 1 knock for the whole run (could be a false positive), but for sure it felt like knock control was pulling a lot of timing up top.
See below:
9-18-log.kdl
thanks!
-Saxon
CalibratEd
Cleaned up some of the fuel. We are moving to VTC 20. Create a normal driving log.
-Ed
saxon_schmauderer
See attached for the run:
Smooth as butter.
thanks!
-Saxon
CalibratEd
Create a similar log. I am cleaning up the fuel. I am glad the car is running well.
-Ed
saxon_schmauderer
see attached:
9-21 run.kdl
-Saxon
CalibratEd
Cleaned up the fuel. Create a WOT log revving the car to 7600rpm. Make sure to hold the car at 3000rpm for about 5 seconds before you do the pull. Make sure you are in 3rd gear and you do it on a flat road. This will help later when blending the VTC tables.
-Ed
saxon_schmauderer
See Attached:
9-22 run x2.kdl
-Saxon
CalibratEd
Cleaned up fuel. We are moving to VTC 30. Create a normal driving log. What VTC gear are you running? I don't seem to have it in my notes.
-Ed
saxon_schmauderer
I am out of town until Wednesday, but I will run that tune when I get home. I have a k20 head / components so it is a 50 degree vtc gear.
thanks!
CalibratEd
saxon_schmauderer wrote: Fri Sep 23, 2022 2:34 pm I am out of town until Wednesday, but I will run that tune when I get home. I have a k20 head / components so it is a 50 degree vtc gear.
thanks!
Sounds good. I need the make and model of the car so i can get the weight, the tires you are running and the transmission you are running. This is needed for the virtual dyno software.
-Ed
saxon_schmauderer
It's a gutted kswapped 2005 Lotus Elise. It should be about 1900 lbs with a full tank of gas.
It has the 6 speed transmission out of an 04 acura rsx.
I am running 245/40zr17 tires on the rear.
-Saxon
