Xdi fuel pump not enabling?
FlashPro Manager software
561_type_r
Post by 561_type_r »
Is there a certain process, step or procedure I am missing to enable my xdi HPFP. I just go to the fuel pump tab, enter serial number, and the code Xdi provided? Then in theory this should change the fuel pump control to enabled from not enabled?
Re: Xdi fuel pump not enabling?
What is the serial number?
Chrisp1
Post by Chrisp1 »
that's correct, although I just went through the opposite where my xdi pump was already enabled without inserting the code/serial number...
I'm not sure if this is a glitch with hondata software or what's going on, was told my pump was indeed enabled and have full access to all pump controls even so
561_type_r
So, I tried all the info I received with the pump, the serial number on the pump, and what was provided to me on the box. I’m starting to maybe think this pump is the wrong one and didn’t belong in this box in the first place. I contacted xdi and they provided me with the code but I didn’t give them the actual serial number off the pump itself. It’s been an absolute nightmare dealing with this vendor and he’s lied to me a good amount so I am skeptical that it’s even the right pump to begin with in the box that it came in since there wasn’t a code and fittings were missing. So the info I gave xdi from the box(not off the pump) might be the code for another pump… If that makes any sense. When I upload my new tune from the tuner it tells me it’s not enabled on my flash pro so I don’t think the pump has been enabled before? Sorry for the long post, I am not that great with hondata, I waited too long for this pump, finally got it on and now I cannot run the car. Here’s the info I have for the pump.
I've remove the serial & code image so that someone else does not use it before you get the chance to.
Does the HPFP show as enabled in FlashProManager? If so, then you don't need to do anything else.
561_type_r
I had to contact xdi and they had to make me a new serial number and code in their system to enable it. Thanks for the reply but I got it sorted now.
