Fk8 Cruise Control not Working
m_kluch
Post by m_kluch »
Im getting e-tuned by IMW. From the very first revision that Drob sent me I lost the ability to use cruise control. The cruise control can still arm and disarm (lights up grey) but it will not set and hold speed when I command it to do so (turn green). I have tried all gears as well as a wide speed range. I have Hondata TC enabled in the tune and that works as it should. I contacted Drob about it and he said he didnt turn off my cruise control and has zero ability to do so. Any advise would be helpful.
Re: Fk8 Cruise Control not Working
What vehicle do you have? What ECU do you have?
m_kluch
Post by m_kluch »
2018 civic type-r with the factory ecu
The next step would be to clear the error codes for all modules using the 'OBDII Diagnostics' windows then 'Diagnostics' tab.
Then post the calibration. If you do not wish to post the calibration here then email it to support@hondata.com
