tuning question?
95lshatch
tuning question?
Post by 95lshatch »
this may sound stupid but im barely geting into tuning. i have a non vtec ls motor and i want to tune it my self, so that i can learn. on the smanager it says low speed fuel and ignition and than high speed fuel and ignition. from reading on this website and tutorials, that is for a vtec engine high speed fuel would be after vtec and low speed would be before vtec. since i dont have vtec should i only be tuning the high speed or low speed tables or make them both the same. IM confused please help.
locash
Post by locash »
Welcome to the forum! You should only be tuning on the low cam tables, unless you have a need for more resolution and higher rpm..
Good luck, and be careful when using the ignition tables, that is an easy way to damage a perfectly good motor..
95lshatch
Post by 95lshatch »
thanks for the awnser now i understand it better
cinq
Post by cinq »
locash wrote:Welcome to the forum! You should only be tuning on the low cam tables, unless you have a need for more resolution and higher rpm..
Listen to Locash...he's the man. :) Also, it's best you don't mess with the ignition tables until you know what you're doing.
Good luck learning.
