new mapp required 410cc injectors and more
B0BSK1
Re: new mapp required 410cc injectors and more
Post by B0BSK1 »
awsome bud thanks ill give it a whirl looking forward to hitting up the track soon too so should be sweeet
B0BSK1
Post by B0BSK1 »
havent had a chance to do any logging. due to the car needing a ball joint and the non geniune rocker gasket i used failed within a month. deepjoy. looking to get sorted out this week and will also test fit new pipe work for j37 Tb
hope alls well look forward to next ripp once shes tight going full polly bush up front befour i tackle the rear
the never ending listr lol
GAOHONGXIN
Post by GAOHONGXIN »
EFICU wrote: Wed Apr 27, 2022 9:51 pm Sounds good. When are you installing the injectors? Let me know and I will get the first file put together for you.
需要帮助,本田 K24交换讴歌 RDX410CC 喷油器,喷油器停滞时间数据?
感谢
