Help for fg2 calibration needed!
EFICU
Re: Help for fg2 calibration needed!
Post by EFICU »
Yeah it looks like you got it right. The reading is a lot better. Luckily I've had enough experience now with this type of failure I can almost spot it a mile away. Haha.
So we almost nailed it on the first try there. I made a couple small adjustments. Take this one for a spin when you can, same datalog and driving style.
ryanthom209.SD.Rev02 (Blended)(Vtec4600).fpcal
ryanthom209
Post by ryanthom209 »
Here you go!
EFICU
Post by EFICU »
Looks pretty good. Go ahead and make another datalog this weekend if you have some time. I want to see if there are any trends in the fuel data between this and the next datalog before I make any adjustments.
ryanthom209
Here's my newest datalog. It seems to be running pretty well, no complaints from me about it.
EFICU
Post by EFICU »
Okay it looks pretty good. For some reason it doesn't want to lean out on the part throttle fuel. It's not a huge deal, but I might change the strategy on it in the next one. Take this one for a spin when you can, and we'll see how it looks.
Which o2 sensor did you buy?
ryanthom209.SD.Rev03 (Blended)(Vtec4600).fpcal
ryanthom209
Huh, thats strange. I got the OEM Honda sensor, hope it's not defective. I'll take it for a drive sometime tonight or tomorrow morning.
EFICU
Post by EFICU »
It could be more MAF sensor based, I was just curious which one you got is all. If it stays the same, we will switch to speed density.
ryanthom209
Here's my recent datalog. My car is gonna be in the shop getting repainted over the next couple days, so I probably won't be able to get another datalog for a bit. If you are curious I'm learning how to do some paint and bodywork and am going to repaint the roof since it has the dreaded clear coat failure. Once again thank you very much for all your help.
EFICU
Post by EFICU »
Yeah the part throttle fuel just won't come in. It's not terrible, it's just not responding as it should.
Let me know when you get the car out of the shop, and we will change strategies to speed density in an effort to dial it in.
ryanthom209
Hey just so you know my car will be ready to drive tomorrow afternoon. Thank you!
EFICU
Post by EFICU »
Sounds good. Give this one a drive when you can. I've swapped the strategy, so let's see how this one looks.
ryanthom209.SD.Rev04 (Blended)(Vtec4600).fpcal
ryanthom209
Here's my datalog.
EFICU
Post by EFICU »
It looks a lot better. Take this one for a spin and we'll see if it accepts the adjustments.
ryanthom209.SD.Rev05 (Blended)(Vtec4600).fpcal
ryanthom209
Here's my datalog.
EFICU
Post by EFICU »
Looks really good, it's definitely more consistent this way. I made a couple small tweaks to the WOT fuel. Other than that, it looks solid. Take this one for a spin when you can. This might be the one.
ryanthom209.SD.Rev06 (Blended)(Vtec4600).fpcal
