Secondary Intake Runner Control
FlashPro Manager software
7plymaple
Post by 7plymaple »
I am setting up a 2015 Civic for autocross and have used the Vtech calibrations to stop the i vtech from engaging by disabling the Vtech oil pressure switch and setting the upper and lower limits of the vtech rpm window above the rev limiter. It feels completely linear through the revs now but is not breathing at the top end because the intake runner isn't switching anymore.
Is there a way to have the intake runner still switch at a set by me rpm without the v tech happening?
I'm not sure what makes the intake change runners stock but I am thinking the change might happen when the revs hit the upper limit of the vtech rpm window. I'm contemplating setting the upper and lower limit's of the window to the same number hoping Vtech will not happen but the runner change will.
7plymaple
Re: Secondary Intake Runner Control
Post by 7plymaple »
This is for an R178 civic I forgot to mention.
7plymaple
Post by 7plymaple »
So I think I figured it out. I set the V Tech rpm window lower and upper limit to the same value and the result seems to be the runner change happens and the car never goes to eco mode. I think I will try the first event the way the car is.
I am very happy with the throttle response and performance I have achieved thanks to Hondata.
