Need help tuning
chrisconig0
Need help tuning
hi i have a 2015 si with a ktuned 3.5 intake and a invidia q300 cat back exhaust. i have a flashpro for my car. so my problem coming is that i can drive the car fine (afr is a little off) but if i sit and idle too long the car goes into limp mode and throws throttle body codes and im not sure what to do. i have 2 datalogs- 1 idle and 1 city driving
Re: Need help tuning
We would need to see which calibration you're running to better determine the issue. Sounds like you're running an AFM based calibration which will most likely cause a similar issue to what you say. With the K-Tuned intake, then should be tuned speed density (MAP based) to get the best drivability.
chrisconig0
im running the prl intake tune. ill attach the calibration. the codes im running into - p0507 idle control system rpm higher than expected - p2101 throttle actuator system malfunction - p2176 throttle actuator control system idle position.
i do appreciate the help. thank you in advance
Yeah that's a MAF based calibration which is most likely the cause of you issues. It needs to be tuned speed density IMO.
Are you planning to add any performance mods in the near future?
chrisconig0
yeah i plan on it. but my daily recently go into an accident so this became my daily till i can find a new one. i was hoping to just make it a good reliable drive until then. i was wondering what my best way to find a speed density imo, im kinda new to all this
No problem. If you plan to add mods in the near future, I can put you on a completed files and we can make it dialed for your car. It may not make as much power as a complete custom tune for your car like I generally prefer. This way saves both of us a lot of time to get you going quickly, then when you add more parts we can spend the time to tune it properly.
Let me know though, I can send that over and you can start making datalogs. It's very simple to tune it speed density and it will almost 100% remove the issues you're experiencing.
chrisconig0
yeah if you wouldnt mind. honestly appreciate the help. i tried looking all over about fixing this issue and nothing was really relevant online
Okay, give this one a drive when you can. We'll see if the codes persist, and go from there. Make the datalog in the 20 minute range and get a clean third gear WOT pull from 2500-7500 in there so we can see the WOT fuel.
chrisconig0
i took a few logs for you today. thank you again
Looks pretty good. I don't see any codes in the system. Does the issue appear fixed on your side?
chrisconig0
sorry i just got off work and all but everything feels goodm up until i idle for about 10 minutes or so and it goes back into limp mode. i can try and get you a log for when it happens if that works
Gotcha. You can just let it idle at home if you want. See if you can get it to do it and hopefully a code or something will pop up we can see.
chrisconig0
so i tried to let it idle for about 20 m,inute or so and it didnt go into limp mode, which seems pretty good but i have a cel, but nothing stopping me from driving. heres what hondata shows
Yeah that doesn't show anything we can use unfortunately. Did you make a datalog for the idle? If so, post that, I might be able to see the code in there.
What does it show under the "DTC" tab?
Either way, keep datalogging when you drive the car in hopes we can capture the limp mode issue and try to diagnose it.
chrisconig0
so i was able to get it to get the check engine light. its throttle body malfunction. it took about 25 minutes. its at the very end of the idle log
