We are working to dial in our Honda LS VTEC (B18b1 w/GSR head). We have Hondata on and running, online with set timing to 16- go under hood and set initial timing at 16deg advanced on the motor.
Return to pc and hit ok and gauge in Hondata continues to read high at 24-25... Double checked cams and crank marks all line up tp TDC.
I have tried this a few times and can't figure out why it doesn't match up... New to Hondata so any help is appreciated!
LS VTEC - Cant sync timing
Re: LS VTEC - Cant sync timing
When you click "close" on the "Set Ignition Timing" window, the ECU allows all the compensations for RPM, temp, etc to be applied again. This is normal.
