15 SI looking for help on a tune
15FB6Si
Re: 15 SI looking for help on a tune
Post by 15FB6Si »
Just reset the entire throttle body learning and fixed the idle! I can log a run a sent it in here in a lil bit
EFICU
Post by EFICU »
Great news! We’ll see how it looks.
15FB6Si
Post by 15FB6Si »
heres the next log
15FB6Si
Post by 15FB6Si »
heres the next log
EFICU
Post by EFICU »
It looks good. The throttle relearn worked good. I cleaned up a couple areas of knock and some fuel touchups. Take this one for a spin when you can.
15FB6SI.SD.Rev05 (Blended)(Vtec4500).fpcal
15FB6Si
Post by 15FB6Si »
ill takee it out now!!
15FB6Si
Post by 15FB6Si »
one is some highway higher speeds and one is more stop and go and pulls
EFICU
Post by EFICU »
It looks really good. The knock we had before is gone, we had a couple random ones in this one in a different area. So I touched that up. Other than that, I'm splitting hairs now on all of it. We're pretty much there, just looking for no knock now. Take this one for a spin when you can.
15FB6SI.SD.Rev06 (Blended)(Vtec4500).fpcal
15FB6Si
Post by 15FB6Si »
i can run this first thing in the morning and I'm free all day tomorrow if you need me to run more if it even needs it. car feels so much smoother and consistiant.
EFICU
Post by EFICU »
Okay sounds good. Yeah glad it's running solid, it looks good in the datalogs. Just trying to tighten things up as best we can and make sure you don't have any knock. We'll see how it looks tomorrow.
15FB6Si
Post by 15FB6Si »
I really appreciate it man. and i got a general question. How accurate is the hondata unit with calculating hp and tq numbers? I know they are not fully accurate because there is no g meter and its calculating off sensors so was curious to know how close.
EFICU
Post by EFICU »
You're welcome. To be honest, I don't know how accurate the Hondata calculation is so I can't speak to that directly. In general, the way all the apps like Hondata work and the virtual dynos, they are very sensitive to uphill or downhill scenarios, bumps in the road, rough roads, etc. It's all a calculation of time, speed, and gear ratio to determine hp. So it has to be taken with a grain of salt, or two. You really have to find the smoothest and flattest section of road somewhere, and make a few pulls on that road in the same datalog. Then run them through the Virtual Dyno software to even get some idea.
15FB6Si
Post by 15FB6Si »
ahh gotcha.. i just ran that next revision
EFICU
Post by EFICU »
That one looks great. No knock, all fuel stuff looks good. Go ahead and take it for another drive and we'll see how it looks. We might be there.
15FB6Si
Post by 15FB6Si »
I’ll take that for a run later today
