Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
I just downloaded the new update and have a 4K Display. The scaling of everything is now messed up when I open Flashpro Manager. I tried changing the scaling of my computer which somewhat changed it but I still can't see certain parameters. Are there any settings within Flashpro Manager to remedy this problem?
Hi there, so the issue with the maximum load is still there, it will not allow more than 0.57psi under "Maxium Load" under the "Conditions" Sections on the active tuning page. I have updated the flashpro manager, even tried to do a new map to see if that was it, and the issue is still there.
staticspeed wrote: Wed Mar 02, 2022 10:46 am
Please tell us what scaling you are using in windows, the size of the monitor and what windows version you have. Also do you have more than one displayy?
I’m also having this issue I’m on windows 10 pro
No scaling helps
No restore works either
When I select graph templates the words are overlapping the boxes
Zoom doesn’t help
Changing the style in setting doesn’t help
Running the program compatibility on different windows versions doesn’t help
I went back windows update that didn’t help
None of my other programs have any issues.
I did not have this issue on 3.8.8
I was able to get it work running a lower screen resolution with less zoom but now all my other programs I use are off.
I have other programs that now won’t display correctly and I have to change my screen resolution every time.
The problem is in the zoom. It doesn’t zoom everything the same.
It would be helpful to know the screen scaling and monitor size as requested above so we can fix this. Until then we will do a release today with the scaling setting as an option in the settings.
