Can anyone tell me if this looks like it will support boost. It should support 11 psi boost for GSR, but cannot determine this for sure. Anyone know how read this stuff?
Previously I believe it did but looking at basemaps for boost in SManager the high speed fuel table seem to have much larger values than in high fuel table for the attached tune. I know the injectors are incorrect they should not be set at 240.
I do not understand the values in high fuel table what are they 800, 900, 1130, none of these seem like air fuel ratio values and nothing I've found makes any sense. If I knew what these numbers meant would be much easier to determine at least if I'm even viewing a calibration that is tuned for boost.
HOw Tell if this Tuned for Boost
TurboTeg332
