Help : base map for k24a turbo crx
K24crxnz
Post by K24crxnz »
Hey Guys
Hoping someone could help me with a base map for my first start up .Will be tuned properly but just wanna make sure she starts up and have no glitches before booking my tune..
Mods:
88 ef crx running kpro v4
K24a a3 motor
Skunk 2 IM
1170cc xspurt injectors (currently using stock injectors ,planned to run stock for first start up then changed over when getting tuned).
Wallbro 450 fp.
50degree rbc cam gear
Speed factory 3 bar map sensor
Ktuned tps
Gt3582r turbo
Deleted iacv
Any help will be muchly appreciated.. if you need more info let me know..
Thanks all
CalibratEd
Re: Help : base map for k24a turbo crx
Post by CalibratEd »
What ecu are you running? Do you have a working wideband? Have you installed the stock injectors?
I can help you out.
-Ed
Instagram: calibrated.tuning
K24crxnz
Post by K24crxnz »
Thanks for the reply CalibratEd
Running a kpro v4.
No I havent got a wide band yet but will buy a aem air fuel ratio gauge sometime next week..
I still have the stock injectors in the fuel rail..should I leave it stock or switch it over to the 1170cc ? I was going to change it to the 1170cc but didnt know how to change it in the kpro so didnt want to risk it..
Thanks so much for ur help man..
CalibratEd
K24crxnz wrote: Fri Jan 28, 2022 10:38 pm Thanks for the reply CalibratEd
Running a kpro v4.
Not a problem. I relied to your PM
