BUG of Flashpro
sifuzhuanyong
BUG of Flashpro
2016 Civic China version MT cannot display wheel speed in recent Flashpro
Honda HDS can detect wheel speed
Restore the original factory program Flashpro can not read the wheel speed
As shown
As shown
Re: BUG of Flashpro
The HDS gets the wheel speeds from the ABS. The FlashPro only datalogs from the ECU.
sifuzhuanyong
Re: BUG of Flashpro
Versions prior to 3.8.4 are available, but later updates will not work
Re: BUG of Flashpro
Agree, I can see individual wheel speeds before in FP datalog. Most probably there is an issue after they did a version update thats why you cant view it anymore.
Im sure hondata can read individual abs speed since they themselves use it in their traction control software. They cant simply claim over night that they can no longer datalog it since it is not from ecu module.
Re: BUG of Flashpro
Then give me the version number where it did work and the version number where it did not work.
Also tell me the what calibration ID the ECU has and also swear to me that you are not changing the ECU binary using third party software.
sifuzhuanyong
Re: BUG of Flashpro
The latest version here is only 3.7.5 and 3.8.4, 3.7.5 can be seen, 3.8.4 does not work, I swear to make sure that I did not use any third-party tools to change the ECU binary file
sifuzhuanyong
Re: BUG of Flashpro
Last calibration file used
sifuzhuanyong
Re: BUG of Flashpro
The ABS data cannot be recognized even after restoring the factory calibration. This should have nothing to do with the ECU program, right?
Re: BUG of Flashpro
I can't answer that without knowing how you are trying to read the ABS.The ABS data cannot be recognized even after restoring the factory calibration. This should have nothing to do with the ECU program, right?
sifuzhuanyong
Re: BUG of Flashpro
The actual test V3.8.7 (23 December 2021) has solved this problem
