What basemap should I use ?
Re: What basemap should I use ?
Okay gotcha. The knock count jumped pretty good on that last datalog is why I ask, by quite a bit. I would recommend taking it easy on this tank of gas, once you refill let's make a new datalog and reassess how it looks. I don't want to make a bunch of changes based on bad fuel or lower octane at least. So let's just take it easy on this tank, once you fill up again, make a new datalog and we'll see how it looks, then go from there.
Im lost with these datalogs again but i dont know if this is it. If it isnt i will datalog again as i tried to organize it again. And also i havent updated hondata as im still on 8.0 and its up to 8.2 but i havent had time. But i will update it right now.
Yeah, it's hard to say but being that new gas was introduced it sure seems like the culprit. I went ahead and made some ignition changes to check. The majority of the knock are happening in a couple areas. A few of them are caused by your rev matching on downshifts and stuff, but the bulk are from the two areas I mentioned.
How much gas is left in the tank right now?
Give this one a drive, once you put new gas in we will go back to 8.9, but throw this one in there for now.
That gas for the last datalog was put a day before the datalog so I’m almost like full tank at the moment.
Okay. Well upload 8.10 and we will see how it goes. Worst case, we will go back to 8.9 once you get through this tank and reinspect.
I have a data log just I’m trying to download onto the pc and upload it but every time I download it, it doesn’t save under the folder I have the data logs so I made a new one and nothing, So hopefully I figure this out soon.
Make sure you have the computer set to show all file types and hidden files.
Sure will , and also I’ve been trying to update hondata to 3.83 but every time I press download it fills the bar all the way up but doesn’t update. I’m still on 3.8. What would that be ?
Thank you for the help spunkster! Finally got the datalog , was having problems downloading onto the computer but finally. I hope this looks good.
I am going to go in and look for some trends. At this point it almost seems like false knock. But let me look through a few files and try to make some determinations before making that decision. This one shows considerable knock still, so let me do some homework on some past files and datalogs.
Sorry to insert myself into this thread but apparently I can’t send pm until I participate more…. Anyways, I was hoping for some help on my flashpro calibration. 100% stock except for suspension. Please let me know if you can help or possibly lead me in the right direction? I appreciate you in advance.
I responded to your other thread JQ.Jq08fg2 wrote: Sun Nov 07, 2021 2:11 pm Sorry to insert myself into this thread but apparently I can’t send pm until I participate more…. Anyways, I was hoping for some help on my flashpro calibration. 100% stock except for suspension. Please let me know if you can help or possibly lead me in the right direction? I appreciate you in advance.
