- Firmware updated to version 201
- Added warning message when locking to an ECU and the ECU binary does not match the calibration ID.
- Added message to unplug FlashPro from vehicle when updating firmware.
- [2022 Turbo Civic] Added support for 2022 Thailand Civic 64E-Z61
- [2016+ Turbo Civic] Added support for Canada 2020 model 5AF-CH1
- [2016+ Turbo Civic, 2022+ Turbo Civic] Added CVT temperature to datalogged sensors
- [Spoon Sports] Added support for 2021 N-One model 5K7-971
- [Spoon Sports] Fixed datalogging bug for 2021 N-One
- [2015-2017 FK2 Civic Type R Euro/Asia] Added injector size
- [2017+ FK8 Civic Type R] Added injector size
- [2017+ FK8 Civic Type R] Added modification to increase maximum valve overlap during spool
- [2017+ FK8 Civic Type R] Added support for 2018 Euro 5BF-E15 binary
- [2017+ FK8 Civic Type R] Added support for 2019 Euro 5BF-E25 binary
Download here
FK8 Cam Overlap
The FK8 limits cam overlap during spool, where the exhaust cam will be advanced to limit overlap. We have added a modification file to disable this limitation. More overlap significantly improves turbo spool up at the expense of higher EGTs during this period. Note that the FK2 does not have this limitation. We will add some datalogs as time permits.
FK2/FK8 Injector Size
The FK2/FK8 now have the injector size (like other models). If you increase the injector size then the ECU will automatically reduce the pulse width to keep the correct fuel trim. For people using the Hondata Fuel System you can either compensate for the larger injectors by applying a fuel trim of -19.5% (current method) or you can zero the fuel trim and set the injector size to 1330cc. If you re-apply the Fuel System modification without zeroing the overall fuel trim you are going to run lean, so do not do that.
Note FK2/FK8 injector sizes are measured at 100bar & 25C.
10th/11th gen Civic CVT Temp
We've added the CVT temperature to the list of sensors for the 2016-2021 and 2022+ Civic CVT. Note that you will need to update your dash app to V1.6.0.0 or greater if you wish to display the temperature on the radio/navi.
