Calibration for 83mm LSVtec
TJCRX
Post by TJCRX »
like stated in the title I need a calibration to turn on and break in my motor
83mm Ls Vtec
B16 head
supertech valvetrain
b16 cams
Skunk2 Ultra Manifold
Skunk2 72mm Throttle Body
Stock Injectors
Bored 83mm B18B1 Block
CP Forged 83mm Pistons 9.8:1
Manley H Beam Rods
Thank You
CalibratEd
Re: Calibration for 83mm LSVtec
Post by CalibratEd »
I can help you out. Can you provide datalogs with Wideband data?
-Ed
Instagram: calibrated.tuning
TJCRX
Post by TJCRX »
I havent turned it on yet, its a fresh motor.
I was looking for a good basemap first then i can send you that information. thank you
CalibratEd
TJCRX wrote: Mon Aug 16, 2021 8:37 pm I havent turned it on yet, its a fresh motor.
I want to make sure you have a wideband. You can’t dial in the calibration file without one. I didn’t see one listed in your post.
-Ed
TJCRX
Post by TJCRX »
my bad man yes i do have a wideband, actually wiring it up right now
CalibratEd
Load the file and calibrate the TPS.
Post the file with the calibrated TPS and a data log of it normal driving if possible . Make sure the engine coolant temperature is above 177F when you are data-logging.
What input are you using for the wideband?
Are you running an idle air control valve?
Have you synced the engine timing?
-Ed
