KManager 4.4.9
KManager 4.4.9
V4.4.9 (1 Aug 2020)
  • [KPro4] Fixed lambda display from AEM 304100
  • [KPro4] Fixed CAN output frequency
V4.4.8 (20 Jul 2020)
  • [Kpro4] Firmware version 18
  • [Kpro4] Added CAN output frequency to parameters
V4.4.7 (16 Jun 2020)
  • [Kpro4] Firmware version 17
  • Fixed tuning via Bluetooth not connecting.
  • [Kpro4] Increase CAN output to 100 Hz
Download here
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread.
DriverMikeD
Re: KManager 4.4.7
Post by DriverMikeD »
The can transmission rate is obviously faster after logging the canbus. However now it is too much data for the dash, so it will requiring filtering. Is there anyway you could just create a drop down to allow adjustment from say 10hz, 20hz or 100hz? Doesn't S300 allow this? This i'm sure is creating havoc for alot of people using other dashes with Kpro using the Canbus. I appreciate the support thus far.
regards,
Re: KManager 4.4.7
No good dead goes unpunished - now we have to work around poor design in the dash where they can't processor the packets at 100 Hz.
We can add a variable frequency output like the s300.
If that doesn't work then we'll roll back all the changes to before the CAN output was altered and call it a day.
DriverMikeD
Re: KManager 4.4.7
I think you'll put smiles on many faces by adding that feature. Very much appreciate it. Thank you.
DriverMikeD
Re: KManager 4.4.7
The dash manufacturer has already applied filtering and got the dash working correctly so it is not an immediate concern. However, I think Hondata customers would enjoy the same feature that is in Smanager. Nonetheless, I appreciate all of the support.
regards,
Re: KManager 4.4.8
We added the variable frequency CAN output.
DriverMikeD
Re: KManager 4.4.8
I appreciate version 4.4.8 and all the effort you have put into adding the adjustability. For some reason though I can only get this version to transmit at at max of 9hz even with the value in Kmanager set to 100hz, if you go lower than 100hz it drops slowly to around 5hz. In version 4.4.7 you were transmitting at a true 100hz, i'm not sure what changed but to keep it simple is there a way to roll this back to version 4.4.7, from what I understand that seemed to work for many people. I apologize for the cycling and appreciate everything you all are doing.
regards,
Re: KManager 4.4.9
I've released 4.4.9, and checked the CAN output follows the frequency set in KManager.
