s200 vs stage 2-4 ecu socketing p28 Is there a difference?
aSTeRiX_2kSi
Post by aSTeRiX_2kSi »
I'm purchasing a p28 socketed for use with a stage 2 system and wondering if any modifications will need to be made for it to be socketed for my s200 or are they the same?
I remember the old s200 tech article specifying the diffences and how the s200 was more reliable etc... and I could have sworn that one of them was how the (e(e)p)rom was socketted to the ecu...
Thanks for the help, if it turns out to be the same I've just found a good deal for myself. Otherwise it'll be a waste to have to get it resocketted again.
-Luciano
AndyE
Post by AndyE »
I upgraded from a stage 4 to an s200 system with my P28 and did not have to change any wiring inside the ECU, just had to swap the interface box and burn a new s200 EPROM. The ECU modifications are the same for stages 2, 3, and 4, so it's safe to say that you should be fine.
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
aSTeRiX_2kSi
Cool thanks, I'm curious now what they meant by improved reliability with the S200 then. Other than software...
FYI - I am now $150 poorer thanks to you! :lol:
AndyE wrote:I upgraded from a stage 4 to an s200 system with my P28 and did not have to change any wiring inside the ECU, just had to swap the interface box and burn a new s200 EPROM. The ECU modifications are the same for stages 2, 3, and 4, so it's safe to say that you should be fine.
-Andy
-Luciano
