Requesting a B20V basemap
anonymous408
Post by anonymous408 »
Hello Hondata family,
This is my first post and quite new to tuning. Can somebody help me with an initial basemap for my new build? Any tips and feedback greatly appreciated.
THANK YOU IN ADVANCE!!
- B20Z block 11.3:1 CR
- RC Engineering 440cc injector
- 84mm cast ITR pistons
- JG port and polish GSR P72 head
- Victor X intake manifold ported to 70mm
- 70mm throttle body
- SuperTech valve train
- BLOX Type C camshafts
- Buddy Club cam gears
- PLM Big Tube 4–2-1 header
CalibratEd
Re: Requesting a B20V basemap
Post by CalibratEd »
I can help tune the car. Do you have a wideband?
-Ed
Instagram: calibrated.tuning
anonymous408
CalibratEd wrote: Tue Jun 01, 2021 10:48 am I can help tune the car. Do you have a wideband?
-Ed
Yes! Wideband hookup on the way. I’m dropping in this motor as soon as I can and will hookup wideband.
Question, do you have a feel of what HP you think this setup will produce?
CalibratEd
By looking around the forums people have made 200-230 on similar setups.
- Ed
anonymous408
Around the same ballpark what I estimated. By the way Ed, hooked up wideband.
I’m currently using a stock b17a map from my previous motor to crank it up.
anonymous408
Would you like me to provide you anything from the wideband or Hondata to get started?
CalibratEd
anonymous408 wrote: Thu Jun 10, 2021 2:00 pm Would you like me to provide you anything from the wideband or Hondata to get started?
Post the current tune and a datalog to make sure the wideband data is in the datalog file. What wideband are you using?
-Ed
anonymous408
Unfortunately there’s a minor vacuum leak I gotta fix first (wrong TB gasket).
As soon as I get that all fixed I can do some street pulls. I’m using AEM Uego 30-4110 with Bosch sensor for wideband.
CalibratEd
anonymous408 wrote: Sun Jun 13, 2021 9:57 pm Unfortunately there’s a minor vacuum leak I gotta fix first (wrong TB gasket).
Sounds good.
-Ed
anonymous408
Finally got it on the road and fixed the leak.
- Wideband installed and used 2001 ITR map.
- was tipped off to use 310cc as stock injector size
Heres some normal street driving. Let me know if you need more pulls. I can try to do it tonight. Thank you in advance!
CalibratEd
What input do you have your wideband connected to? Did you sync the timing? Does your wideband gauge match the reading in Hondata?
-Ed
anonymous408
I’ve connected via the O2 D14. Wideband hooked up all good and numbers matches hondata to the wideband.
anonymous408
Oh yes forgot to mention I synced the timing too.
anonymous408
CalibratEd wrote: Tue Jun 29, 2021 8:48 pm What input do you have your wideband connected to? Did you sync the timing? Does your wideband gauge match the reading in Hondata?
-Ed
Here's the current map and datalog file (most recent)
CalibratEd
Load the tune and datalog the car normal driving. I smoothed out the map to have a base to work with.
-Ed
