2016 Ariel Atom K24Z7.
Flashpro model: 2012+ Civic Si US 2013+ ILX
The base map I have has vehicle calibration listed as a 2012 Civic SI US, I sent the tune to an e-tuner who modified it and sent it back to me and now it won't upload, it says the tune is for a 2014-2015 Civic Si. The tuner didn't change the vehicle calibration. He even went so far as to try again only changing the name of the file and not making any modifications. Does anybody know or have you encountered the problem of the flash pro software changing the vehicle from a 2012 to a 2014-15 for the tune and not being able to upload the tune?
Upload error
Re: Upload error
What year is the ECU and engine out of?
For the base cal, are you sure you picked it from the correct drop down menu? 2012 and 2013 on on their own, and 14-15 is the same.
Can you post the calibration so we can see it?
Re: Upload error
Hi, the ecu and engine are a 2012 Civic Si. Attached is the original calibration (1-13-20) and the updated one (ChrisAriel...) that switched calibrations after being saved. Thanks for the help!
Re: Upload error
Interesting. It's definitely two different years as you can't change the year and model under the calibration tab.
With that said, there isn't much difference between the two files. I can swap over the changes from ChrisAriel file to the 1-13-20 file so you can get back on track. I'm guessing you need the immobilizer turned off as it was in 1-13-20 right, you didn't swap the ignition switch from the Civic into the Ariel right? The ChrisAriel file doesn't have it disabled.
Let me know.
Let me know.
Re: Upload error
Maybe I can't, I tried transferring the changes but it still shows fuel changes after I swapped all the fuel data. There probably isn't much you can do besides having your tuner redo the changes to your 1-13-20 file and resave it as a 2012. Maybe the Hondata boys will chime in for you. Sorry I couldn't help you out on this one.
Re: Upload error
I'm having a tuner look at it tomorrow, hopefully I can get it straightened out. That's correct, there's no immobilizer being used. Thanks for taking a look at it!
