Greddy turbo kit questions! K-PRO
Ravenous Si
Ok installed my greddy kit intercooler kit 550 rc injectors and kpro.Downloaded map and started car.when it starts it idles at 2000 for about a minute then drops to 1000 the begins to surge from 1000-2000.I have checked the car 6 times for vacume leaks,I have replaced the cut lines that I spliced into with new lines with no splices leaveing out the bov and turbo acuator and still surge.the car is a 05 so everything is new only 4000 miles on the engine.I have made sure the injectors are seated and they are.
WHAT ELSE COULD BE THE CAUSE NEED HELP!!
Ravenous Si
Ravenous Si
Ok i did that and I loaded the IAC slider with the car not running because I was loading the parameters with the car running.
Now the idle comes down to the 800 at idle but when you come down off of the rev it still wants to bounce a little then it will come back to idle.And the idle comes up when the cooling fan comes on.
Is this running conditions normal?Not sure if the cleaning or my loading cured it?
Ravenous Si
Ravenous Si
Ravenous Si
Ravenous Si
Ravenous Si
