FlashProManager V3.6.9
FlashPro Manager software
V3.6.9 (6 Jan 2021)
  • Firmware updated to version 192
  • [2017+ FK8 Civic Type R] Fixed 'new calibration' not using improved throttle selection.
  • [2017+ FK8 Civic Type R] Added support for 2020 Euro model 5BF-A34 and 2020 Japan model 5BF-J13
  • [2017+ FK8 Civic Type R] Allow indexes for ignition, ethanol fuel, ethanol ignition & ethanol boost to be changed.
  • [2017+ FK8 Civic Type R] Added UK/Euro calibrations for stock and full bolt ons.
  • [2020 Accord] Allow AFM rescaling.
  • [2016+ Turbo Civic] Added support for Canada 2020 model 5AN-CB1
  • [2016+ Turbo Civic / 2017+ Civic Si] Added knock sensitivity & boost by gear quick select
  • [2016+ Turbo Civic / 2017+ Civic Si] Allow ignition index to be edited
  • Allow CARB calibrations to change non-tuning related modifications.
  • Added two calibration permissions to optionally allow the use of tuning and non-tuning modifications in restricted calibrations.
Download here or from the Help menu.
Please only reply to this thread with issues & questions specific to the changes in this release. For all other problems start a new thread under the appropriate vehicle category.
Notes
The 2018, 2019 & 2020 Euro FK8, 2018 UK and 2019 Asia FK8 'Exhaust cam (spool cold)' tables are incorrect from Honda. We have left the table as delivered by Honda since it is relatively minor but if you wish you can copy from any other FK8 calibration to fix the table.
hapv
Re: FlashProManager V3.6.9
Post by hapv »
Still not working for 93 octane, intercooler, impoved throttle for FK8 Americas
When a calibration is saved in the computer the DTCs are modified
janemar
Post by janemar »
- Please elaborate more. I see no change coming from 3.6.8 version.
- Where can I see ignition index?
Double "Improved throttle response" bug???
2017 1.5CVT Thai user.
toasst
Post by toasst »
Everytime I try to update Flashpro manager on my laptop it continues to say “error downloading the update. Pease download again.” I have tried 6 times and I have tried restarting everything. No luck.
janemar:it is there for the 2017 Thailand CVT. Post your calibration.
toasst: your antivirus is deleting the application. http://www.hondata.com/forum/viewtopic.php?f=1&t=8240
fujinz
Post by fujinz »
I have problem with this software. Can't play the datalog
fujinz
Post by fujinz »
First time I tried works well I can read datalog but second time trying to read datalog again always pop out that warning. Please help. Im from Indonesia
janemar
Post by janemar »
Hondata wrote: Sat Jan 09, 2021 8:57 pm janemar:it is there for the 2017 Thailand CVT. Post your calibration.
Just to clarify, are you referring to "knock sensitivity low" tables for all cylinders? I can confirm that I already have this feature from version 3.6.8.
What I can't see is the "knock sensitivity quick select?" OR it is juat the same?
fujinz: post the datalog
janemar: knock sensitivity and boost by gear quick select. Not knock sensitivity quick select and boost by gear quick select.
janemar
Post by janemar »
Hondata wrote: Sun Jan 10, 2021 8:25 am fujinz: post the datalog
It's not new then, I recalled I already have knock sensitivity tables on the version 3.6.7
fujinz
Post by fujinz »
Here is my datalog. So the situation when opening only the datalog it self is working normal. Also when opening the calibration only it working normal. But the problem comes up when opening both, calibration and datalog.
janemar wrote: Sun Jan 10, 2021 9:57 am It's not new then, I recalled I already have knock sensitivity tables on the version 3.6.7
Not all models had knock sensitivity tables.
fujinz wrote: Mon Jan 11, 2021 5:00 amHere is my datalog.
Thank you. We will need to do another release to fix this, which should be shortly.
