Stock jdm Itr dc5 with rbc intake manifold
Hi, today I’m install hondata k-pro v.3 in my jdm ITR 2002 year, did any have kal to my spec? Stock + rbc intake manifold + exhaust kakimoto full mega n1rev+ Cai
BrianJewell1988
Re: Stock jdm Itr dc5 with rbc intake manifold
I just swapped a 2004 DC5 Type R K20A into my 2005 RSX Type S.
My mods are...
RBC Manifold plus 70mm TB
Injec CAI
BuddyClub RACE Header (pretty huge primaries, noit the normal one)
Thermal 3" Catback
Stock 310cc Inj's
-7 iridium plugs (in case you've changed heat ranges...)
If you like I have a street tuned map that has gone through 20+ minor revisions to be as good to daily drive as it is at WOT, unlike a lot of KALs that just dial in your AFR, Timing, and maybe some VTec Angle tweaks to make a peak number.
My mods are...
Injec CAI
Thermal 3" Catback
Stock 310cc Inj's
1990 R32 GTR:Nitto 3.2L,7675 G2 SM,PPG,Hypertune,ARC,Nismo&other bankrupt-esque brands 1081AWHP@44psi on E98
2005 RSX Type S:DC5R K20A,Ported RBC/70mmTB,Injen CAI,GearX 1-4,Quaife 2 way,5.06 Gears,TL-S Brembo's, Wilwood Rear BBK,Fortune Auto 510's,etc
Hey Brian,
i was wondering if you can share your map... I will soon have a similar setup to yours on my ITR.
Yes share it please just did the same swap
BrianJewell1988
I'm on my way home from work, will post the map ASAP...Sorry I missed these replies!
Just FYI, my mods are as follows;
BrianJewell1988
I'm posting 3 maps.
Please log and verify on your own car!
ALL are tuned for US Spec 93oct ☆☆RON+MON/2
For you Shnurokkk, thatd be like your Shell VPower with a 99 RON number or so just as a heads up.
First is titled "Rev 6.2 ..." this is what I'm currently running and is tweaked for WINTER and IAT's in the 25°F to 55°F range, there's a pretty large difference in the fueling being fattened up.
13.1afr target on HiCam.
50° -> ~ 25° VTC
3800rpm VTec Engagement
VTec Oil PSI Sensor DISABLED (K20A Swap, will change eventually)
This tune made 241whp and 165wtq on a dynojet with a 1.00CF, its a good daily driver but IF you're concerned about Fuel economy, the part throttle is not tuned to be Stoich or a bit leaner, it's a tiny bit richer than that.
Note*** My Alternator took a shit so that is why the .KAL is titled that way....
Second is R19
This map is basically for any temp from 45° F and up. Fuel Compensation by temp has been tuned, AFR Target on this is 13.2:1. Cam Angle tables have been Smoothed. Instead of big jumps by RPM, say 50° at 4500rpm then 45/40° at 4750rpm...they've been blended, start and end points are still about 48° vtc to close to 20° vtc up top.
Third is R21
Same as R19, however this map employs a more standard Cam Angle map, no super small and smooth changes in angle, just a slightly more aggressive phasing. This particular map made 234whp on a Mustang dyno on 93°
50° -> ~ 25° VTC
Second is R19
Third is R21
