I got that engine, and I want to put it in the car.
Now if I want to use the '99 distributor, Throttle body and Intake Manifold, do I need to switch to a OBD-2 Wire harness and ECU?
What would you suggest? Is a obd-0 ECU any good?
What is the best solution, I plan on using Hondata.
Give me some suggestions please!
Thanks for your time
'99 B18B in a 1991 Integra
boostedcrx
Re: '99 B18B in a 1991 Integra
Fred_B18B wrote:I got that engine, and I want to put it in the car.
To save your self the headaches ues the obd0(your 91'): dist, injectors and your 91' engine harness and everything should be fine. just make sure you use the 91 crankpully and driver side motor mount. other than that everything should be straight forward.
Stock 1.5/1.6 mutt boosting 1.5 bar
