Ap1 kpro 4 no start
Mikeedc
Ap1 kpro 4 no start
Post by Mikeedc »
I just bought this kpro used from someone locally. I’m having a crank no start problem. The fuel pump prime when I turn the ignition. No spark when I remove the coil. Thanks in advance
Re: Ap1 kpro 4 no start
Did you buy the whole kit with wiring, sensors and valve cover?
Mikeedc
Post by Mikeedc »
Nvm I got it running. I erased the ecu security and put new calibration. It’s running little rough on idle tho. Now my other question is do i need to get it tune or Is it hard to tune it myself?
I'd start by installing a wideband so that you can see what the lambda is.
Mikeedc
Post by Mikeedc »
I got it running good now. I have a check engine light and I disable the code p0135 because I have a hf cat. Can I drive the car around with this calibration for a while or do I need to get it tune asap?
You will need to datalog and make sure that the AF ratio is safe, and that there is no knock.
Mikeedc
Post by Mikeedc »
Do I need wideband to check the airfuel ratio. I tried datalogging and the a/f wasn’t changing (14:7) the whole time. Do I need to turn on anything before I datalog because I don’t see anything on my tables. Last question is do I need my laptop connected to ecu when changing the fuel map and ignition?
Yes you need a wideband to be able to read AF. Yes the laptop must be connected and you can only use Kmanager to make any changes. YOu must also have your calibration open to see the tables.
Mikeedc
Post by Mikeedc »
I just bought an aem eugo wideband and got the hondata connector from the ecu. Is there any good write up for install.
Mikeedc
Post by Mikeedc »
What about the other wires from the aem.
Mikeedc
Post by Mikeedc »
The aem net + and -
They are not needed.
Mikeedc
Post by Mikeedc »
Oh ok so just the white and brown. And the black and red ( run with inline fuse). Aemnet + & - not needed and the blue as well
correct.
