K20/24 12:5:1 basemap
Parkercole
I have a k24a2 block bored .5 over with wiseco 12:5:1 pistons, eagle rods, cosmetic 0.30 head gasket, type s 4 piston ported oil pump with a stock k20a2 head for now in an RSX. The TSX calibration provided on the preloaded calibrations makes her knock pretty bad and I was looking for a basemap that I can break in this build with.
- CalibratEd
- Contact:
Re: K20/24 12:5:1 basemap
Post the calibration and a datalog with a wideband input and I can help remove the knock you are experiencing.
-Ed
-Ed
Instagram: calibrated.tuning
Parkercole
I have since had the car tuned on a dyno thank you for the reply tho!
- CalibratEd
- Contact:
Great to hear. I am glad it is up and running.Parkercole wrote: Sun Aug 16, 2020 7:01 pm I have since had the car tuned on a dyno thank you for the reply tho!
-Ed
With cr 12.5:1 how much ignition is in wot high cam?
Oem camshaft?
Oem camshaft?
Parkercole
40 Degrees with k20a2 camshafts
40 degrees in wot high ??? impossible
I thought no more than 25 degrees of ignition in column 9 in wot
