time for a revisit (partially cause I was wrong concerning running tsx curves on a 2 lobe vtec k24a1)......
the knock sensitivity curve for 2 lobe vtec motors seems to be correct after all.
I hooked up a headphone amp to the knock sensor with the .1uf cap and 100k resistor like in this thread https://www.k20a.org/threads/how-to-lis ... ock.27258/ and went for a ride.
I adjusted the timing some and loaded it in low to mid rpm ranges to get a little knock and when i heard a ping in my headphones, i would get knock count.
I wonder if the 3 lobe vtec valvetrain makes a bunch more noise, or if the intake contributes to more noise or the higher power resonating the block makes more noise in those engines that makes the knock sensitivity curves higher.
Brian
K24 knock sensor sensitivity differences.
reliant_turbo
Return to “K-Pro Calibrations”
Jump to
- General
- ↳ Hondata News
- ↳ Applications
- ↳ Non-Hondata
- s100/s200/s300
- ↳ s300 / SManager
- ↳ S300 Calibrations
- ↳ SManager Display Templates
- ↳ s100/s200
- ↳ Romeditor 4 Software
- ↳ HondaLogger Software
- ↳ Coil Pack Retrofit
- K-Series
- ↳ K-Pro / KManager
- ↳ K-Pro Calibrations
- ↳ KManager Display Templates
- ↳ K-Series Reflash
- FlashPro
- ↳ FlashPro Manager
- ↳ FlashPro Calibrations
- ↳ Accord 2008+ FlashPro
- ↳ Civic Si 2006-2011 Americas
- ↳ Civic Si 2012-2015 US/Canadian / 2013+ ILX
- ↳ Civic Type R 2006-2010 Japanese FD2
- ↳ Civic Type R 2007-2011 European FN2
- ↳ Civic Type R 2015+
- ↳ Civic 2016+ 1.5 Turbo Americas/Asia
- ↳ CRV 2017+
- ↳ CR-Z 2010-2012 US/Europe/Asia
- ↳ Fit 2007-2008
- ↳ RDX 2007-2012
- ↳ S2000 2006-2009 Americas/Europe/Asia
- ↳ TL 2007-2008
- ↳ TSX 2004-2014
- Traction Control
- ↳ General / Traction Control Manager Software
- ↳ Traction Control with S300
- ↳ Traction Control with KPro
- ↳ Traction Control with FlashPro
- Bluetooth Mobile Apps
- ↳ Hondata Mobile
