Hey everyone so I have an Lsv turbo set up I have stock injectors at the moment as well as stock fuel pump, however I need a tune to get the car going for now. Meanwhile I'm waiting for the fuel pump, I had a 255 walboro gave up on me in 6 months-_- I had 440cc injectors same deal got clogged
I do have Hondata s300 and would definitely appreciate it if someone has a base map I can use meanwhile 🤙
Gsr head Is block
Poor man type r set up
Gsr transmission
Need a Lsv tune turbo to run meanwhile
therealkeeg
Re: Need a Lsv tune turbo to run meanwhile
I have the same setup just with 550cc injectors, if you still need a tune lmk. You would just have to change the injector sizing in the tune.
