2012 Honda civic si knocks
Re: 2012 Honda civic si knocks
Okay good. I just wanted to make sure they are just little crackles which is normal, especially with really small throttle input like you mention and gear changes/decels.
Yeah use 8.1. Since the ones above that had a little more crackle I am just going to stick with the 8 number and make variations of that. I'm hoping to stop the knock during the shift on the 3-4. Seems to only do it when it's really hot, but we'll keep an eye on it.
Yeah its not as hot today
The 8.1 have knocks
The 3-4 gear change again only? Or in other areas too?
Im upload it now
yes 3-4 wot
Okay I think I may have figured out where and why it's doing it. I made some changes to keep it from going into the area where it is causing the gear change knock. Give this one a try.
was driving crazy doing pulls in each gear
Well, progress anyways. No knock between shifts, but a couple during some of your pulls. I went ahead and took a bigger swing at the ignition in the areas of knock. I was trying to creep up on it, but this time I took a little bit bigger swing at it. Give this one a try, we should be good on this one.
seen one
This one was in a whole new area, so I took some out there as well. At least still nothing on the gear change or on the high cam. This one should do the trick then.
was a raining day coulnt data log much yesterday
Okay I think we're finally there. I don't see any knock in those datalogs. You had a lot of pulls in those datalogs with no knock, so I don't see you having any issues. Make some datalogs for fun over the next week or so and if you see some knock let me know. If not, it looks like it's good to go.
i had a knock in #2 but didnt record it but other than that its fine
