im currently using the ips base map but have maxed out the stock injectors and purchased a set of 750's, yes they are overkill right now but i have some other plans later on.
my question is the following: does the kpro have a injector rescale or do i have to manually subtract a certian percent of fuel across the board?
i found the injector size tab in the parameters section but when i input the new size i get no change in the fuel table?
how to rescale injectors?
Re: how to rescale injectors?
I haven't switched injectors while using one calibration, but as I understand it, all you have to do is change the injector size and it will adjust things 'well' -- the values in the fuel tables will not change, it is all behind the scenes. You will have to fine tune fuel still as all injectors flow differently, but by putting the injector size in there, it will get you in the right ballpark to clean up fuel.r@mon wrote:im currently using the ips base map but have maxed out the stock injectors and purchased a set of 750's, yes they are overkill right now but i have some other plans later on.
