I switched to Bar from "/PSI because the indicator was showing negative value when I used "/PSI.
This is really weird. I have Flash Pro Manager installed in my desktop and laptop. Both showing the same negative value when I use "/psi.
I finally find the answer & happy to say that I’m happy I’m wrong in interpreting boost pressure.EFICU wrote: Sun Jan 05, 2020 11:37 pm I also think a good idea may be to put the ECU back to stock, and recheck. If it was something in the tune, that would tell you. But I am pretty sure it's the setting I mentioned in the above post.
I will run longer datalog tomorrow. Hopefully, traffic would be friendlier than last week.since this is absolute pressure on the intake, 1.5bar is 0.5bar above 1bar (atmospheric pressure) and is perfectly normal for 2000rpm. Always subtract 1 from your MAP sensor input to find the turbo pressure.
Hi EFICU,EFICU wrote: Mon Jan 06, 2020 3:02 pm Sounds good. Always nice when you can eliminate a fear, especially like overboost like you were.
Look forward to seeing how it looks.
I used the standard calibration but I'll try the calibration with MAP to determine WOT for tomorrow morning run.EFICU wrote: Tue Jan 07, 2020 9:41 am it's getting better, the MAF scaling is + or - 2% throughout 90% of the voltages. Just a couple are still a ways off. Did you use the MAP to determine WOT file or the standard file?
Also, the knock seemed to creep up when your intake temps got to 118* F. I am curious because in these files they have no temp compensation for intake temps. Not sure why, I don't have enough experience with 10th gens to know. But if we pull some timing out in the hotter temps like you saw the knock, it should help in that area.
Let me know what you think.
Yes, I'm in warm side of the world. Lowest ambient temp in my city is 77 F. Average temp about 90 F and could reach 97 F in the summer. I'm considering custom intercooler because known brand intercooler will cost me close to USD 2,000.EFICU wrote: Tue Jan 07, 2020 7:31 pm Okay sounds good. If you're not worried about the knock we can worry about that later. And yeah, I would think pulling a couple degrees of ignition in the higher temps of that air temp compensation table would help relieve some of that knock.
Yeah an intercooler might help some, I would do that over the radiator if you decide to do it. I feel like I saw it somewhere, but aren't you in a usually warm part of the world?
If you are going to try the MAP for WOT file, try the one below. I made the changes necessary from your dataog you posted earlier regarding the MAF scaling. So try this one below.
EFICU.REV03Arnoldod.Current-Plus-3PSI-Calibration-R1_11a (MAP to determine WOT).fpcal
I also noticed that the dip is mostly occur during fueling transition scenario as the car coming to a stop. Other than that the trim is great!EFICU wrote: Wed Jan 08, 2020 5:57 pm Yeah the MAF scaling trims looked great on this one. Where it has the deep dips in fuel trim might be a transition fueling scenario as you're coming to a stop it looks like. But other than that, the trims are within a couple percent, which is great. The MAP for WOT seems to be a big help for these cars. Like I said, the other guy on here I helped he said it changes the characteristics of the car and it makes the fueling a lot more consistent.
I will look into the IAT retard for ignition and see if it applies to your car. If so, I would pull a couple of degrees in that table which would probably remove a lot of the high temp knock that you see. But with these new ignition tables from Honda, I don't know them as well as older model Honda stuff.
Here is the newest version if you want to try it. I made changes around those dips in fuel trims, I didn't touch anything else. If they don't get better on this file, it has to be something regarding fuel transition on coming to a stop. Which I am not sure we can get rid of without a lot of work, if at all.
EFICU.REV04Arnoldod.Current-Plus-3PSI-Calibration-R1_11a (MAP to determine WOT).fpcal
