Hi,
I have a Euro CTR (with PRA ECU) with CAI and SuperSprint header+exhaust. And of course k-pro.
As you can see from the attached datalog at relatively low rpms and light throttle, ignition jumps up and down to the set value in the tables (see attached cal). God knows why. If this happens the engine sounds like it has bronchitis...
Other than this I don't experience any problems.
Any idea what this could be?
Strange Ignition behaviour
racing-honda
racing-honda
I have a similar problem.
My idle is between 11 and 22? Ignition, but I put 18.5 for 1000rpm and 20.5 for 1250rpm.
My A/F is 12.8-13.2 at idle, because I don't want misfire error with 750cc injectors
Look between 10'07 and 11'31.
