K20a2 Pra ecu Street tuned Kal
Raidenreda
Post by Raidenreda »
Hello everyone this my Kal street tuned on 95 pump gas my mods are skunk2 ultra manifold with IMG ktuned Cai and headers skunk2 3" exhaust and aem wideband in closed loop as primary sensor. Can anyone check it if its properly tuned and if there is still more to adjust to get the maximum performance. Thank u in advance
(the kal had popcorn on it) here is the kal in attachement with some 3rd 4th gear pulls.
[/url]https://www.sendspace.com/file/0n6kk8[/url]
Hpmengine
Re: K20a2 Pra ecu Street tuned Kal
Post by Hpmengine »
Post your achievements and calibration here, and you can verify what problem you have ...
if you want me to help you....
regards
Raidenreda
Everything is in the link below my post
Hpmengine
Post by Hpmengine »
HELLO
Use 98 fuel ...
New spark plugs and a good GAP IN THEM!
The ignition tables are not bad, although they can be improved, the slips are important, so as not to have those small losses in Vtec, ignition, etc.
The small pulls without trying it is difficult to know, but I think it occurs in the ignition, by pressure readings .....
That is what I saw in your records
And it can increase the CAM
Replace the WOT system ... (OPTIONAL)
With lambda card and everything else ... (MAP, TPS, ECT ...)
(OPTIONAL)
Regards
Raidenreda
Thank you for your reply
95 fuel is the best i can get here and my spark plugs are new and pre gapped didn't get you about the WOT system
Hpmengine
Post by Hpmengine »
if the GAP of the spark plug is important, but if you don't have fuel with 98, it is a problem ....
What grade of spark plug do you have?
I will try to adjust the map so you don't get jerks, where are you from?
regards
Raidenreda
The spark plugs are oem IFR7G-11KS im living in north Africa that s why there is no dyno or tuners over here and its the only K swap in the whole country.
Hpmengine
Post by Hpmengine »
What part of Africa? if you need help send me MP,
I will help you without any problem ...
spark plugs grade 7 are fine ...
sadness not having rum fuel 98 ....
regards
