Cam angle map info??
Hi guys, sure it's a very easy question but on the cam angle maps on hondata if I selects the 0 degrees map for instance why in that map are there angles that are not 0 degrees?? It's the same thing with all the other degrees. Cheers
Re: Cam angle map info??
The cam angle maps are populated with the values for the amount of cam advance you want. The only time you can look at the tables for specific cam angles is in the fuel and ignition tables.
Mmm still don't get it lol so when I use the drop down menu and look at 10degree map and see values from 0-40 etc why aren't they all 10? What do the numbers represent? I know they are cam aims but why are there higher than 10 cam aims in the 10 degree cam map?
What vehicle are you referring to?
Type r fn2 K20Z bro
Watched a few videos but still don't fully understand
Have you read the info in the help file: https://www.hondata.com/help/flashpro/t ... or_vtc.htm
I have bro but I still lile I need a better explanation of hoe the tables are used
Please read the info at:
https://www.hondata.com/tech-rsx-vtec-vtc
https://www.hondata.com/tech-vtec-crossover
The VTC table has a composite map that has the best cam advance settings for making power.
Yeh I understand what the principles are bro...but I mean you have to tune earth cam angle map right? I just don't get how we tune 10 degree map with other numbers than 10. Lile on low load why does the 10 degree angle map have 25 and that in it? I've attached a pic
The CAM angle map tells it which cam angle fuel and ignition map to use for that load.
But there is numbers in the middle that are different to 0 degrees cam angle....surely the 25/35 degrees should be in the 30/40 degree mps from drop down menu??
Yeh I just don't understand why in the drop down menu of "0 degrees" there are values of 25/35 etc
There is no drop down for this in in FlashPro Manager.
The screenshot you have posted is of Kmanager which is not used for a FN2.
